Question Problem configuring Cisco switch ?
Mar 18, 2024
I have a Cisco C9500 48Y4C Switch.
I tried to configure it with this command:
"power redundancy-mode combined"
but the switch doesn't recognize this command.
why this happen?
the command write ok? or i need to change something?
Is this command necessary in this switch?
More information needed:
What is the specific error message or other response presented when the command fails?
What is the source being referenced for the command and its' format?
What all have you tried and what resulted from each attempt?
Your question appears to be a homework or test-like question. Forum rules prohibit doing homework.
May or may not be homework but no way to know from this end.
Simply provide more information and we can go from there.
It is unclear why you are using that command. Does the switch have multiple power supplies.
Make sure you are entering the command from the proper area. Some commands you must be in the proper config mode.
It has been a while since I kept up with the details of cisco stuff. Be sure this is not some stupid software related version thing where the command only works on certain releases of firemware.....which of course you pay extra for with cisco.
Latest posts
