R Robert_339 Commendable Jan 8, 2017 1 0 1,510 Jan 8, 2017 #1 what bluetooth head phones can i connect to my samsung 32" hd tv ( UE32K5600AK ) and what make must they be ie: sony- phillips ???
Solution A A americanaudiophile Jan 10, 2017 If your TV has bluetooth (the manual says not all of this model have it) you should be able to use any bluetooth headphones.
A americanaudiophile Titan Aug 27, 2008 13,663 0 101,360 Jan 10, 2017 Solution #2 If your TV has bluetooth (the manual says not all of this model have it) you should be able to use any bluetooth headphones. Upvote 0 Downvote Solution
A alisazlotenkoitf Mar 16, 2018 1 0 10 Mar 23, 2018 #3 Yes, you need to check the specifications in order to be sure that Bluetooth is supported. If yes, try simple: restart) Upvote 0 Downvote
