Problem connecting through switch.
ajtonyb02
9
Hi! My problem is, that my pc (win10) doesn't connect to wired internet via zyxel switch (es-105a v2). But if the internet comes through the Wifi router, there's no problem with connecting. (The router can't offer the full speed of my internet.)
Any ideas?
OK, the reason that doesn't work is that the ISP keeps track of MAC (network hardware) addresses. You would have to call and ask the ISP to reset your connection. BUT, only one device can connect to the ISP. The switch won't allow multiple devices to connect. The FIRST device the ISP sees an IP request from is the one that connects. All others get nothing. You REALLY need a router. The job of a router is to allow multiple devices to share a single IP address from your ISP.
Wired ports on routers are switches (also). They are also connected to the WIFI and WAN. Bandwidth between wired ports on a gigabit router will be gigabit. What ISP speed do you have?
What do you think about the tp-link archer c1200? I think it can do almost everything what's important.
1. It has 1000mbps lan ports and wan port.
2. Its wireless speed is maxing out at about 1000-1100mbps too
It is a $50 router. It won't compete with more expensive routers. That might be OK if you don't need a lot of features or have to support a lot of WIFI devices.
Here is the review of that router from the same website as the R700 review -- https://www.smallnetbuilder.com/wireless/wireless-reviews/33015-tp-link-ac1200-wireless-dual-band-gigabit-router-archer-c5-v2-reviewed
There are multiple versions of the C1200. One has three antennas and one has two. I think the three antenna version is better.
