Problem Default Gateway page cant load
tiger2shadow
Hello All :
my problem is when i try to accsess my router page it says cant access or page not found
i tried to login from adiffrent computer & browser & mobile
i tried to reset the router and reconfigure it again but the problem disappear for 2-3 days and come back again ...any of u have solutions or fix or any thing i will appreciate it !!
my router is tp-link TD-W8901G
i try to login to 192.168.1.1
also my Dhcp is enabled i hope its not a router configuration prob...
my ipConfig /all
Host Name . . . . . . . . . . . . : NeMo
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR8131 PCI-E Gigabit Ethernet Con
troller (NDIS 6.20)
Physical Address. . . . . . . . . : 6C-62-6D-F3-55-0F
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::ec93:4378:33c6:1f91%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.6(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 18 ?????, 2015 10:40:22 ?
Lease Expires . . . . . . . . . . : 21 ?????, 2015 11:40:30 ?
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 241984109
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1B-35-14-95-6C-62-6D-F3-55-0F
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 9:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.{311808D9-E80F-4805-899B-11D6E7832CAC}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
