[Problem] display problems really need help
rb2crens
21
i had a problem with my Monitor last night...
It begins to display some weird-colored-line or everything else (shortly happens after i played Test Drive Unlimited games a couple hours before...)
i think there's only 2 reason : Monitor or VGA card problems, but dont know which one that caused it....
until today its still show the problems.
The colors shows displayed unconsistence i see
UPDATE: after some try on some games, it appears some texture colors are not correct
PIC:
Sorry My Bad English
I think theres a problem with one of your data wires of the monitor try replacing it with a new one and if possible u might also wanna clean the inside of your monitor as dust balls may cause resistance in the path of escape of the heat.
Hope this helps !
