Hi, yesterday I formatted my new HD203WI with partition magic (just a large partition), my SO is XP so I tried to run for the first time even Paragon Alignment Tool (it said that all my partitions are not aligned), just to figure how it work because I want to buy even some F4 HD204UI and I am aware about the 4K sector problem with XP. The tools apparently did hits work and everything seemed to work well, but when I open partition magic it says that now the new drive is damaged, I tried to format it again, but it was not possible (an error message appears after POST).
Do you think it’s a normal behavior of PQ magic after paragon did change its layout of the partitions or I did something wrong? I can leave it this way or it’s a problem to solve?
Now I can try some other program or the windows utility, but I don’t know if run again Alignment Tool.
Thank you
Thank you
