Problem G.Skill Trident Z RGB F4-2400C15Q-32GTZR Asus Z170 Pro Gaming/Aura is the motherboard.
I-FISH
Commendable
Dec 13, 2016
7
DDR4 Trident Z RGB Asus Z170 Pro Gaming Problem
DDR4 Trident Z RGB F4-2400C15Q-32GTZR
I just purchased and replaced the ram on my Asus Z170 Pro Gaming motherboard. I can not find a way to change the LED bars on the ram to different colors/patterns. The G.Skill website states that they are Asus Aura Sync ready. I have downloaded the software for the MOBO and I can change the colors patterns on the MOBO and the Gigabyte GPU.
So is there something I am not doing correctly?
Thank you in advance
Next ASUS Aura update should have Trident Z RGB support.
ASUS has their own Aura software to configure Trident Z RGB with Aura capable motherboards.
G.Skill will have proprietary software for the Trident Z RGB RAM to be used in any motherboard with specific chipsets such as Intel Z170/270, and more to come.
G.Skill said they're gonna release software (that can control RGB LED) following in February
So you gotta live with that rainbow poison since the ram default mode is rainbow effect until they release the software i think
And maybe they need an update for mobo to do aura sync I guess
iceZ thanks. I just received this message from the G.Skill Tech
Private Message: Re: DDR4 Trident Z RGB F4-2400C15Q-32GTZR
Yesterday, 06:15 PM
GSKILL TECH's Avatar
GSKILL TECH GSKILL TECH is offline
Administrator
GSKILL TECH has disabled reputation
Default Re: DDR4 Trident Z RGB F4-2400C15Q-32GTZR
Software is not ready yet, should be available in upcoming weeks. Keep an eye out for updates.
