G
Guest
Guest
Hello! I am looking to get a good replacement for my current GPU. It's mostly okay but I've saved enough now to get a reasonable upgrade.
My current card is fine apart from once or twice a month the driver will crash (the screen will freeze/flash pink with artifacts) and it will either recover on it's own or it won't and I'll have to reboot my computer. I've tried everything I can think of to troubleshoot why this keeps happening (uninstall/reinstall software/hardware, update drivers, check connections). It's a GTX 750Ti that I've had since early 2015. It's served me well but there are times when I could use something better.
Few things:
-Is there anything else I could try before getting a replacement?
-I'd like to get a best-fit card that will play nice with my other components (see below). Not sure if it's a thing, but I'd like to avoid getting something that would make the other parts work too hard and possibly fail.
-I'm not a super huge gaming enthusiast but would be open to hearing other recommendations to change any other existing parts.
-Ideally, I'd like a something that performs better than my current GPU while not being an issue for the other parts to work together with it.
-If there's a suitable card that I can upgrade to but will work best by replacing 1 or 2 other parts (limitations of CPU, PSU, etc?), I'd be open to that as well
-Price range is $300-$400
==Setup==
PSU- EVGA 100-W1-500-KR 500W ATX12V
CPU- Intel Pentium G3258 Haswell Dual-Core 3.2 GHz
MB- ASRock Z97 Anniversary
GPU- ASUS GeForce GTX 750 Ti
RAM- 2x G.SKILL Ripjaws X Series 4GB
HDD- Seagate Barracuda ST1000DM003 1TB 3.5" Internal Hard Drive
Monitor- 20" Acer P206HV 720p 60Hz 16:9
Case- Antec NEW SOLUTION SERIES VSK-4000 Black
Few things:
==Setup==
