GamerBoy357 :
if you replace the fans and the thermal paste then yes it will work. just be a bit more careful when reapplying thermal paste on graphic cards as they tend to be more sensitive than CPUs. buy a Artic silver ceramique thermal compound as its non conductive of electricity.
hi ... i did everything you said ... but the pc does not accept the card ... the fans of card works ... and when i put the cable of screen to the motherboard port ... the screen show .... so its like there is no graphic card and the fans run Without avail
sorry for my bad english .... is there a solution
