Problem i have strugled with a few days - copmuter locking!
esorensen
13
Hello Guys
6 months ago i banged my computer on top (I got mad) now it frezzes in games like BF4 and WoW. Now, first i tought it was my CPU-cooler, but i stress-tested my CPU's core uptil 100% i 2 minuts. No problem.
Then i tought it was my RAM, so i tested it with MemTest86 (Passed) - Cool. But then i testet it with ibt (intel burn test) and it FREEZED again.
I tested my computer with other RAM's (same RAM but from diff. computer) and it worked perfectly. But why did my RAM not fail with the Memtest86 then?
I can play games, but not for long. WoW i can play for a long time, but do i start BF4 it crashes almost right away.
So the big question, is it my RAM or CPU or maby a third thing?
I have bought new RAM, CPU-cooler and cabinet cooler, just to be sure (have not recived yet)
Sorry for my bad english (danish here)..
EDIT:
Processor: Intel Core i7-2600K CPU: 3,4 GhZ
RAM: 8 GB (2 pices of Kingston)
something is getting hot.......... cpu or gpu.
or you damaged the cpu internals by banging on the computer.............. rage slams.................. maybe you shouldn't play if it frustrates you so much?
also check for lose connections and see if all your hardware is properly seated in their slots.
I am checking my core temps and when my computer freezes the core is not hot (40-45 degrees). Thats way i tested with RAM's from another computer, and my computer not frezzed.
I will not give up on this. I have just build it for 2000 Dollers, from 1 yr ago, and have only used it for 3-4 month. Too soon to give up.
Thanks swifty_Morgan, will try when new cpucooler arrives.
Where i am concerned is that when takeing out my RAM's and swifting them to other ones (same ones, but from diff. copmuter) - My copmuter did not freeze. So you dont think its my RAM?
