Problem identifying Graphics card model
Hackeey
27
Hii guys actually i have a graphics card with me which i have found in my store room dont know whats it model.. plugged it into my system. its running without driver but i couldn't figure out the model of it anyhow through windows already ran gpu-z but it also couldn't show me the details.. also ran dxdiag...now i am willing to use it.. but for that i will have to install the drivers at first but unfortunately i don't know the model of it..so is there any way i can find out its precise model no. so that i may get to download the drivers for it
If you use Microsoft Update it might automatically download and install an appropriate driver for the card.
To enable Microsoft Update, go to Windows Update and click 'Change Settings' on the left pane. Enable Microsoft Update, click OK and search for updates.
Did you look the card over carefully for any kind of model number. There should be either a sticker with the model/serial number or silk-screened on the card someplace. If you can't find it there go to Device Manager and double click on the device in question and then from there click on the Details tab then the Down arrow and click Hardware IDs. Do a search for the Hardware IDs should give you the vender/model of the card it will be in this format PCI\VEN_***&DEV_***. Where *** and *** is the Vender and Device ID's. Each PCI device has a unique Vender and Device ID. Hope that helps.
actually windows was not able to download the drivers for it...and yes i have tried to read the information on graphics card itself to get any help.. but i only found the the NVIDIA written on it
i have also gone through device manager but there still there's no luck! there's only a question mark on display devices. i would like to tell that it has only 1 hdmi and 1 dvi port for output
Mine was also sarcastic.
Anyways, came up with this.
http://www.ebay.com/itm/Dell-nVidia-GeForce-4-MX-420-64MB-Video-Graphics-Card-8Y483-TS-M-8V01C-/251261572312?pt=PCC_Video_TV_Cards&hash=item3a805b54d8
Geforce 4 MX 420 64MB video card
But another look says huilun02 has got a closer match than me.
