Hi,
I have a problem that Intel consider impossible to solve!
This is the configuration:
I7-2700k
DP67BG (and DZ68ZV. They've send me this board as a replacement)
4Go ram memory KVR1333D3N9HK2/8G (I'm only using one ram of 4gb for the test, and I've tried with an other brand)
Power supply OCZ MODXSTREAM-PRO 600W (I've tried with an other brand)
Basically the problem is simple:
If the ramm is in channel A, everything works fine. If the ram is in channel B, I get three beeps and a 27 code on the board.
If someone solve this problem, he's brighter than at least 6 technicians from Intel and 3 from FutureShop.
Thank you.
N.B.: The motherboard is now outside the case on a none conductive pillow
I7-2700k
Thank you.
