problem in burning dvd
saurabhkumarshs
16
Friends i am using amkette dvd-R and when i burn that dvd with folder containg rar files using nero xpress, it shows burned successfully but when i again insert that dvd, it shows blank. I have used 4 dvds in a row but didn't get help.
G
You might want to try imgburn for burning DVDs. This is the best burning software and it is free. You can customize the burn in many ways.
http://www.imgburn.com/
You might have better success using imgburn.
Also, if you can purchase Verbatim discs in your area, they are the best and I have never had a bad burn of any kind with that brand. Another good brand for less money is Optical Quantum. They are half as much as Verbatims and use the same dye.
If you are still having bad burns, you...
If you are still having bad burns, you might want to make sure the method you are using is "write file to disc" or "write files/folders to disc" and not "write image".
ok i will try and let you know cuz my speed is low now. Thanks
Latest posts
