problem in keyboard
gavidhu
some letters that i write in my keyboard does not work.q,w,e,r,t,y,u,i,o,p,g,h and v. plas help its an emergency.my lap is dell inspiron 15 3000 series.
The ribbon cable may have come loose.
Slide the latches over to unlock the battery.
Remove the battery.
Turn the laptop over and open it up.
Using a small flat head screwdriver, press in the keyboard latches and carefully remove and turn over the keyboard.
You will then see the keyboard ribbon connector.
Check that the ribbon is securely fastened below the catch. You may want to gently remove it, and re-insert it to ensure no dirt has got in.
Reassemble in the reverse order.
This may or may not cure the problem, but this is where i would start!
Good luck and let us know how you get on!
Kenton82
Remove the battery.
