problem in laptop camera,videos,speed,graphics
AaravB
Hey all..
i bought a laptop about 3-4 months ago.it has 1 gb nvidia 820m graphics(dedicated) and 2 gb integrated intel hd graphics.it has 720p camera.i suffers from the following problems :-
1. The camera of the laptop is 720p hd.But it looks like pollution in camera when i turns on the camera,the camera quality behind the pollution looks fine but the pollution is not tolerable,it looks like camera quality is burst .
2. Whenever i play any video in my laptop,the video get burst too.i can only clear that burst about 30 percent of that by adjusting some color configuration.
3. it has 8.1 windows 64 bit with bing.clock speed 2.16 ghz & 2.58 ghz with turbo boost.
but my laptop processing speed is too slow as compare to its configuration.it takes upto 5 seconds for even a single refresh click.
4. Some of the HD video lags also.
AS far as i know, my laptop configuration is really good and these problems can be fixed.
Currently i am using windows 8.1
SO i need your help for this.Please respond fast.
here are the full details of my laptop.
OVERVIEW
Brand Lenovo
Type Notebook
Series G50-30 Series
Utility Gaming
Color Black
Model Number G50-30 80G0018VIN
PROCESSOR
Processor Name Pentium Quad Core (4th Generation)
Variant N3530
Processor Brand Intel
Clock Speed 2.16 GHz Turbo Boost Upto 2.58Ghz
MEMORY
RAM 4GB
STORAGE
Hard Disk Capacity 1 TB
RPM 5400
OPTICAL DISK DRIVE
Optical Drive DVD-RW
Speed 8x
PLATFORM
Operating System Windows 8.1
DISPLAY
Screen Size 39.62cm (15.6)
Resolution 1366x768
Screen Type HD LED Glare (Flat)
GRAPHICS
Dedicated Graphics Memory Capacity 1GB
Graphic Processor Nvidia
KEYBOARD/INPUT
Integrated Camera 720p HD Webcam
Pointer Device Multitouch Touchpad (with Scroll and Zoom Functions)
Keyboard AccuType Keyboard
AUDIO
Internal Mic Array Microphone
Speakers Yes
Sound Effect Stereo Speakers with Dolby Advanced Audio Certification
COMMUNICATION
Ethernet 10/100 Mbps LAN
Wireless LAN IEEE 802.11b/g/n
Bluetooth v4.0
POWER & BATTERY
Battery Backup Upto 5 hours
Power Supply 32 W AC Adapter
Standard Battery 4 cell
PORTS/SLOTS
USB Port/S 1 x USB 2.0, 2 x USB 3.0
Mic In Yes
RJ45 LAN Yes
HDMI Port Yes
VGA Port No
Multi Card Slot Yes
Other Ports 1 x Headphone / Microphone Combo Jack, 1/8 inch Stereo Audio Port
SECURITY
Lock Port Kensington Lock Slot
Size & Weight
Weight 2.4 kg
Dimension(W*D*H) 380 x 259 x 23.9 mm
Color Black
WARRANTY DETAILS
Warranty Period 1 Year Lenovo Onsite Warranty
Hello AaravB
It looks like there is some issue with the graphics driver. Can you please check if the latest graphics driver is installed on your laptop?
You can find all the drivers for your laptop here.
In case this doesn't help, I would recommend you to reset your Windows 8.1 computer to factory defaults.
If the problem persists, you must then take your laptop to an authorized service station. Since it is still under warranty, they would definitely give you the best solution.
Good Luck!!
