Problem in running games even at 30 fps
agharr
8
hi
my name is raheel my pc is
intel pentium 4 3.2 2mb cash
ram kingston ddr2 1gb at 667
G card Xfx 9600 gso 384mb
motherbord intel d945gnt
but games r not running smooth
plz help
me
invisik
2,476
That setup is fairly weak for gaming. Intel p4 is a very old cpu and the 9600gso isnt that strong plus limited to 384mb. You also need more then 1 gig of ram. I would suggest you get a new pc all together, costing around 600$ for a decent build$. If you cant i suggest you upgrade the memory from 1gig to 2-3gig in addition to overclocking the cpu and gpu.
Just curious what games do you play? and at what resolution?
teja92
159
I have got a 9600 GSo 512 and it rocks my 19" screen at 1440x900 resolution.See my configuration dude. You need a min. of 2 Gig for Xp and a 2.6 GHz dual core or a 2.2 GHZ quad core for good gaming.
agharr
8
thanks 4 ur reply
am playing games at 1024*768
wanted weapon of fath is runnig cool cod 4 is runnin cool
but riddik 2 ,cod5 and burnout paradise r not running at play able speed
and about 9600 gso
ihave gone through many reviews there is only 3 r 4 frames difference b/w 9600gso and 9600 gso thats why i bought gso
and i have bought another 1 gb of ram but it doesent make any difference
an i dont have enough money to by a new pc
so now tell me what to do?????
falendar
17
I pieced my rig up piece by piece, You could probably go about doing the same. took me about 3 months, depending on your budget you could hold 100-200 a paycheck and have it built in just a short time.
agharr
8
so whats ur plan to buy now
and what r ur old system specs
falendar
17
Processor AMD Phenom II X3 720 BE
Video Radeon 4850 512MB
Motherboard Biostar TForce TA790GX A2+
Memory 4 gig of ozc gaming memory
Hard Drive 640 gb hard drive
Optical Drive any cheapie will work or you can get a blue ray.
Audio
Case Antec Three Hundred ATX Mid Tower
Power Supply BFG Tech LS Series LS-550 550W
you can upgrade/downgrade per your choice but overall it's a sweet machine.
my old machine was probably worse then yours.
