Problem Installing AOC Monitor Driver
mtaufiq
8
Dear Masters,
I have problem installing new AOC Q2963PM monitor driver.
The message appear on the unfinished installation was:
Cannot Install this Hardware
An error occurred during the installation of the device
A service installation section in this INF is invalid
I have downloaded the driver update, the message is remain the same.
Anyway, the display works fine at it upmost resolutions.
Please, I need your enlightenment or info for any driver sources which fit into my system.
I highly appreciate any of your kind attention.
Thank you Master, Thank you in advance.
Best Regards,
Taufiq
Operating System Windows XP Professional 32-bit SP3
CPU Intel Core i5 2400 @ 3.10GHz Sandy Bridge 32nm Technology
RAM 4.00GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard Gigabyte Technology Co., Ltd. PH67A-D3-B3 (Socket 1155)
Graphics AOC 2963 (2560x1080@60Hz)
2048MB ATI AMD Radeon HD 6670 (Gigabyte)
Thank you very much Darkbreeze for your kind help.
I have installed both of your files. The Intel .inf was successfully installed but the Intel management engine interface is not for my machine, Error: This computer does not meet the minimum requirements for installing the software.
I have also restarted my pc, my driver problem was still there.
Do you have any alternatives which could possibly run on this specs:
Sorry for bothering you so much.
Best regards,
Taufiq
That driver is specifically indicated for your motherboard, as were the .inf files. If a driver designed specifically for your motherboard refuses to be installed I'd suggest that you either have a configuration problem, an issue with the motherboard itself or your windows installation is corrupted and may need to be reinstalled.
And it's no bother at all. We're here to help, or at least try to.
