Problem installing MSI Z87 G45 drivers?
Nagarya
35
So I just completed my first PC build, and after installing Windows 7, I went to install the drivers I had downloaded onto a flash drive from the MSI website:
http://us.msi.com/product/mb/Z87-G45-GAMING.html
7 out of the 10 drivers installed without incident, but I got an error saying my computer does not meet the minimum requirements. The drivers that won't install are:
Intel Rapid Start Technology Driver
Lucid Virtu MVP Driver
Intel VGA Driver
Any idea why I'm having problems? Also, are these drivers important, as in will I be fine for gaming and whatnot if they're not installed?
If you have a discrete GPU it won't install the Integrated graphics unless you start the PC w/o GPU installed.
Lucid MVP Driver is for the 6 sound connecters on the back I don't think those will install either if nothing is connected to them.
Intel Rapid Start I think only works with SSD. I could be wrong there too, or is for skipping the BIOS?
MSI Z87 G45 downloads / Utilities/ Download MSI Live update and use that to SCAN, If you don't have internet connection though this won't work so you have to do all USB.
I have the same board.
Latest posts
