M Maxvj Apr 3, 2020 71 0 30 Nov 24, 2020 #1 When I go to install Realtek audio drivers, it works, but then once I restart it puts me back through the process again ?
Solution rgd1101 Nov 24, 2020 read thru this https://www.tenforums.com/tutorials/2944-add-delete-enable-disable-startup-items-windows-10-a.html
rgd1101 Don't Moderator Nov 7, 2011 74,759 4,209 176,290 Nov 24, 2020 #2 Maxvj said: it puts me back through the process again Click to expand... exact what you mean by that? the audio driver is missing? Upvote 0 Downvote
M Maxvj Apr 3, 2020 71 0 30 Nov 24, 2020 #3 Well my problem is that my system audio plays through any voice communication app i use, so i wanted to uninstall and reinstall realtek and then it started doing this Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,759 4,209 176,290 Nov 24, 2020 #4 doing what exactly? that the question Upvote 0 Downvote
M Maxvj Apr 3, 2020 71 0 30 Nov 24, 2020 #5 When i install realtek on my mobo website, it restarts my computer and when it boots back up the install prompt shows up again Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,759 4,209 176,290 Nov 24, 2020 #6 close it and reboot and still there? did you somehow added to the startup? Upvote 0 Downvote
M Maxvj Apr 3, 2020 71 0 30 Nov 24, 2020 #7 Yes, I just disabled it from startup, and tried to install and it still did it again Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,759 4,209 176,290 Nov 24, 2020 #8 upload a screenshot of exactly what this does it again. upload to imgur.com and post the link here Upvote 0 Downvote
M Maxvj Apr 3, 2020 71 0 30 Nov 24, 2020 #9 https://imgur.com/a/ObjF8F3 View: https://imgur.com/gallery/ObjF8F3 Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,759 4,209 176,290 Nov 24, 2020 #10 what did you disable in startup? sound like you disable the driver not the setup. Upvote 0 Downvote
M Maxvj Apr 3, 2020 71 0 30 Nov 24, 2020 #11 i think the driver how would you disable a setup Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,759 4,209 176,290 Nov 24, 2020 Solution #12 read thru this https://www.tenforums.com/tutorials/2944-add-delete-enable-disable-startup-items-windows-10-a.html Upvote 0 Downvote Solution
