Problem installing the motherboard
Jun 1, 2018
I already installed the cpu, cpu cooler and memory on my motherboard.
But the problem is I can't put it into my case. It a perfectly compatible case, but when I tried to fix it in I can't aline it with the motherboard shield.
I tried my best but I don't want the mother card to break, so I don't know what to do. I looked to some tutorial on internet where it seemed really simple but for me it is very difficult.
If you have any response for that please respond.
Hoetan
Commendable
Jul 24, 2017
174
Could you possibly upload a video to a website like YouTube of you trying to install the motherboard? Or a photo? It is hard to understand what the problem is when we having nothing to look that.
Cheers mate :)
CaptainCretin
Respectable
Jul 18, 2016
625
Have you put the stand-off screws into the backplate of the case?. The mobo sits on these to keep the contacts on the back of the motherboard away from the case metalwork, once fitted, you screw into the top of them with your mounting screws.
If you havent put them in, the mobo will sit too low (and die when powered on).
