Archived from groups: microsoft.public.windowsxp.general (
More info?)
Creating the C: partition first and then installing xp is by far the better
method. Adding partitions via computer management after installation is
then a simple matter - assuming you haven't allocated every inch of your
hard drive space to the windows xp partition.
John Barnett MVP
Associate Expert
http://xphelpandsupport.mvps.org
The information in this post is supplied "as is". No warranty of any kind,
either expressed or implied, is made in relation to the accuracy,
reliability or content of this post. The Author shall not be liable for any
direct, indirect, incidental or consequential damages arising out of the use
of, or inability to use, information or opinions expressed in this post..
"Chris" <Chris@discussions.microsoft.com> wrote in message
news:B636736C-D51F-4778-9F32-49A36DDFB29C@microsoft.com...
> Yes, it's buggy at times. I usually will just create one partion (the one
> that the OS will reside on), install the OS, and then go into Disk Manager
> and create/format the rest of the paritions. I don't know what it is, but
> I've ran into the same problem as you did at various times. I learned my
> lesson and do it my way now. Glad to see you got it working.
> "DeeDee" wrote:
>> Yes, aren't they! NOT. I can't believe how long this has taken. Just
>> to
>> get the OS and partitioning and formatting done. I still don't get why I
>> didn't have the opportunity to select the partition to install the OS on
>> after partitioning the 2nd part of the drive - on either of the first 2
>> attempts to install. The MSKB on it, and John's FAQ that he kindly
>> pointed
>> me to ... both seem to indicate that I should get that option. Oh well
>> I didn't plan on sleeping tonight/last night anyway. :-/
>> DeeDee
>> news:EF41EE63-AEC4-4259-89EB-2CF15BBFB392@microsoft.com...
>> > Yes, unformatted space will not show up under my computer or in
>> > Explorer.
>> You
>> > have to go into the Disk Manager and create and/or format that parition
>> > before Explorer will see it. Aren't computers fun?
>> > "DeeDee" wrote:
>> > > OK, I think I HAVE found the unallocated space. It wasn't showing up
>> under
>> > > My Computer, but I noticed the DVD writer was allocated as E:, and
>> > > when
>> I
>> > > went into Disk management I have 166.77g of unallocated space. So, I
>> think
>> > > I may be OK after all. Sheesh!
>> > > DeeDee
>> > > "DeeDee" wrote in message
>> > > news:#8wf0nlrFHA.3556@TK2MSFTNGP10.phx.gbl...
>> > > > Thanks for your help. I have definitely partitioned the first
>> > > > drive,
>> 20g.
>> > > > And initially the second drive was partitioned with the remaining
>> space.
>> > > > When I went through the install the 3rd time, I deleted the 2nd
>> partition,
>> > > > leaving the balance 180g unpartitioned. And selected partition 1
>> > > > 20g
>> and
>> > > > installed Windows on that partition, leaving the formatting as it
>> > > > was
>> as
>> > > it
>> > > > had already been formatted as NTFS in the first attemp at
>> installation.
>> > > It
>> > > > currently shows Local Disk C: 19.5g total 16.9g free. No other
>> > > > disk
>> > > space?
>> > > > It doesn't show anything as unallocated.
>> > > > Basically, you suggested Option 2 - was what I did on my 3rd
>> > > > attempt
>> to
>> > > > install - with the above mentioned results.
>> > > > Help please.
>> > > > DeeDee
>> > > > "John Barnett MVP" <freelanceit@mvps.org.NOSPAM> wrote in message
>> > > > news:eRzPvilrFHA.3068@TK2MSFTNGP14.phx.gbl...
>> > > > > You have obviously not allocated the partition size and have
>> formatted
>> > > the
>> > > > > whole drive. Windows has therefore taken all of your drive space
>> > > > > and
>> you
>> > > > > have no unallocated space in which to create another partition
>> > > > > from
>> > > within
>> > > > > XP.
>> > > > > Two options:
>> > > > > 1/ Buy a copy of partition magic, shrink the partition down from
>> 200GB
>> > > to
>> > > > > 20GB ( i assume from your partition claulations that you have a
>> 200GB
>> > > > > drive?) This will then give you a 20GB C: drive and 180GB of
>> unallocated
>> > > > > space in which you can create either 1 large partition (not
>> recommended)
>> > > > or
>> > > > > by creating a logical partition, any number of further smaller
>> > > partitions.
>> > > > > 2/ Re-install Windows XP. Only this time simply create a
>> > > > > partition
>> of
>> > > 20GB
>> > > > > and then format this partition. Then let windows install to this
>> > > > partition.
>> > > > > If you have created the partition correctly you should end up
>> > > > > with a
>> > > 20GB
>> > > > C:
>> > > > > drive and 180GB of unallocated space.
>> > > > > For further details on partitioning and formatting with XP visit
>> > > > > my
>> > > > website
http://xphelpandsupport.mvps.org Click the Win XP Faq button and
>> take a
>> > > > look
>> > > > > at question 41. For an illustrated guide to installing windows xp
>> also
>> > > > take
>> > > > > a look at question 85
>> > > > > John Barnett MVP
>> > > > > Associate Expert
>> > > > > any
>> > > kind,
>> > > > > liable
>> for
>> > > > any
>> > > > > of
>> the
>> > > > use
>> > > > > this
>> > > post..
>> > > > > "DeeDee" <dlyle@writeme.com> wrote in message
>> > > > > news:uzt5FalrFHA.2552@TK2MSFTNGP10.phx.gbl...
>> > > > > >I can't believe this. OK. So first off, I setup 1 20g
>> > > > > >partition
>> and 1
>> > > > > >180g
>> > > > > > partition, was stepped through to formatting NTFS for first
>> partition,
>> > > > > > then
>> > > > > > did the same for the second partition. At the conclusion of
>> > > formatting
>> > > > > > the
>> > > > > > second partition it went straight into installing windows on
>> > > > > > the
>> last
>> > > > > > partition it had formatted. I did not get an option to select
>> > > > > > the
>> > > > > > partition
>> > > > > > I wanted to install on.
>> > > > > > I thought I must have missed it the first time, as I was
>> > > > > > working
>> on
>> > > this
>> > > > > > pc
>> > > > > > whilst installing the new system box. So, I started again
>> > > > > > doing
>> the
>> > > > exact
>> > > > > > same procedure. Same thing.
>> > > > > > So, I started for the 3rd time. After deleting the second
>> partition,
>> > > I
>> > > > > > had
>> > > > > > the option to create another partition or select where I wanted
>> > > > > > to
>> > > > install
>> > > > > > windows, I selected partition 1 (c
, and thought I would be
>> > > > > > able
>> to
>> > > > > > format
>> > > > > > the other partition through Disk Management. Went through
>> > > install/setup
>> > > > > > again. And I now have windows installed on c:, but no other
>> > > > > > disk
>> > > space
>> > > > > > available to partition.
>> > > > > > What the heck am I doing wrong? Help please.
>> > > > > > DeeDee
