Problem Launching Medal of Honor Warfighter
TAUHID21
33
Last week I bought Medal of Honor Warfighter from a local store. I install it following the instruction. It was installed without facing any problem, and then when I try to launch it shows the message “Medal Of Honor™ Warfighter Has stopped working. Windows can check online for a solution to the problem.” And then I click “Check online for a solution and close the program” Few minutes later it stops. And then when I again try it again shows the same message.Now I am using Windows 7.
What is the problem?
Please help me to fix it…………………
If you are using a crack then we cannot help you, but if you have bought the game try launching it in admin right and/or disable your antivirus program and/or unblock the internet connection of your firewall for the warfighter game exe.
