Question Problem Logitech X-530 Speakers
isoelite
9
Hello,
i have 2 problems with my 5.1 Logitech speakers X-530
1)The cable of my rear right speaker is broken(the side that i plug behind the woofer) so i cut it.i would like to ask what type of cable should i buy to also cut it and stick them together or is there any other way to fix it.
image upload
upload image
2) My 2nd problem is with the left front speaker which is the main one that you connect it with the pc (green,black,orange jacks) and also with the woofer like a vga cable(i believe is for the power).The problem is with the green jack which is for the right and left fronts.When i plug it to the green jack at my mobo no speaker works by if i turn the cable near the jack left right or stretch it some time left one works perfect but not the right one and vice versa but never both of them work simultaneously so i believe the problem is with the cables near the jack so i want to cut it also like the rear speaker but the question is WHAT cable should i buy that also iam gonna cut it and stick them together.
upload image
Thanks in advance!!
