Sigh...
This is ridiculous. I realize that most likely the problem, like most all of my problems, will end up being something simple that I simply overlooked but if anyone can help me then by all means PLEASE suggest something.
Anyhow my problem is this. Three computers are needed to be networked and all are running Windows XP Pro. The two laptops connects wirelessly behind a Linksys WRT54G Router, and the Desktop connects via an Ethernet cable from the router. First I tried the easy stuff:
1) Used Network Wizard and shut off all firewalls. I even uninstalled a couple.
2) Set all workgroups generically to MSHOME (I used DAS_CASA first but then reconfigured them to run under MSHOME thinking that a more generic name would work better).
3) Enabled simple file sharing on all PC's (tried without it too).
4) Picked different folders for file sharing. No go.
5) Tried to see if the Epson CX3800 printer was available on the network. No go.
6) Registry cleaned, virus scanned, etc. No go.
Basically after all that I could not see any of the computers in My Network Places. I click on My Network Places ==> MSHOME and then the explorer is blank with nothing in the network share. Oh, all computers were of course online and restarted after all this. Then I was sure to double check some setting in the group policy menu and turned off local password access so no password are required.
Then after that I tried to Manually set the workgroup name and file sharing settings. No go. I tried uninstalling and reinstalling TCP/IP. No go. When I ping the computers IP Addresses they show up in the CMD Prompt no problem but I still can't see them in My Network Places.
I tried the program Network Magic by Pure Networks and that worked flawlessly so I know the computers can see each other but why it does not display in my Network Places I don't know.
After reconfiguring one of the laptop PC's it should up in My Network Places and shared everything no problem but only to the other wireless laptop and not the wired desktop. However, the other wireless laptop and the wired desktop were still not showing up in My Network Places. Weird I know. Obviously the router I do not believe can be the cause since on PC is working fine, but what about the others? Is there something I missed under the Group Policy? A built in restriction? Anything? Help appreciated and thanks in advance.
-Fred
-Fred
