Problem: "No Bootable Device - Insert boot disk and press any key" Toshiba Satellite C40D-A
I recently erased the data of the laptop, since I wanted to reformat it and install a new OS. So I went in the utility option when you clicked 0 and picked erase data. I chose "delete all data and partitions from the hard disk". The process went on and finished. When I turned on it says
Check Cable Connection
PXE-M0F: Exiting Intel PXE ROM.
No bootable device-- insert boot disk and press any key.
I tried to plug in my cd and usb with an OS in there, remains the same. Tried restaring, still remains the same. I checked the Bios Setup/boot, the hdd is still there and my usb as well can be seen in there.
The laptop is already old and does not have any warranty anymore.
Help?
MERGED QUESTION
Question from exsaviorcage : "Problem: "No Bootable Device - Insert boot disk and press any key" Toshiba Satellite C40D-A"
