problem recognize 6gb ram 1600mhz on asus P6T7 WS bios
skeletoon
17
Hi.. Memory setup 1600mhz 6gb on motherboard asus P6T7 ws supercomputer . I have problem of config 6gb ram memory 1600mhz corsair on motherboard P6T7 WS asus. Can you help to find me correct setup XMP overclock? windows recognize fine, but bios read only 4048 gb.
Motherboard recognize only first channel A1 + A2 , black and blue slot. I have plug 2 ram banks 2gb+2gb. If I add any ram banks in other channels B1 or B2 or C1 or C2 it doesn't recognize, but it doesn't even return error in Auto config. But if I modify XMP menù manual setting, with every setting, it returns error to the boot. The problem is that I have never made a setup manual in XMP, I don't know the parameters. Memory fully compliant with motherboard, it's corsair TR3X6G1600C8DG
You must set the memory to X.M.P mode in BIOS setup, so that the memory will run at 1600MHz. Please follow the instructions below in BIOS setup:
1. Set「Ai Tweaker」-->「Ai Overclock Tuner」to 「D.O.C.P.」
2. Set「Ai Tweaker」--> 「DRAM O.C. Profile」to 「Profile#1 or Profile#2」,
and then press F10 t0 save and exit.
check in BIOS\Advanced\Uncore Configuration\Memory Remap Feature is enabled. This may make full RAM available
I will post a pictures but i don't know how to do. ?!
I have looked for in DOCP but it it doesn't have profiles #1 or #2 but it's in menù XMP.
I have looked for in menù advanced bios but the menù "Uncore Configuration" it is not present.
I have tried to start DOCP setting with three rams bank in slot blue it from error with led blue power up.
With menù bios Ai twiker-->Auto and three rams bank in slot blue it recognize only 2048.
With menù Ai Twiker-->Auto and two rams bank in slot channel A1 blue and channel A2 black it only in this way configuration recognized 4096gb.
I don't know for post a pictures here. It can help ?
