Question Problem sharing wireless connection between three buildings
Aug 5, 2024
I have fiber internet / router in Building A . I have a TP-Link AC1200 wifi router in Building B which connects wirelessly to building A and works fine. If I connect a laptop to the LAN port of the AC1200 I have a good internet connection. Between building B and C, I have Ubiquiti Nanostations creating a wireless bridge. If I connect a laptop to the wireless bridge in Building C, I do not get an internet connection. For testing, I have a TMobile cellular internet router that I can connect to the wireless Bridge in Building B and then the internet works like it should in Building C. Can anyone explain why the wireless bridge works fine when I connect it to LAN port on the TMobile router, but does not work when I connect it to the LAN port on the AC1200 router. Thanks!
This is likely all related to the problems with using wireless repeaters.
From what I can tell the cases that work always have something connected via a lan cable.
It seems what you want to do is connect from a-b wireless and then run b-c also via wireless.
Basically this is a wifi repeater. The issue is wifi is intentionally designed to prevent this. The mac address is used as part of the encryption standard to prevent man in the middle attacks....which is exactly what you are attempting.
There are a number of so called hack/solutions. The most standard one uses a field called WDS to pass the mac addreses. Although not part of the wifi standard most device now do it the same way. Problem is WDS is considered a security exposure and many times you must turn the feature on in the main router.
It might still be messy because your building C might also need to run as a repeater. You generally can't run repeater to repeater with WDS. You might be be able to run building C as a wifi bridge and then hook a AP to the bridge to provide another source of wifi.
Pretty much what you are trying to do is MESH. Because the problem with the wifi encryption still exists all the implementations of mesh are proprietary so you can't mix and match equipment.
In addition TPLINK has some other speical bridge modes one of which is called universal repeater.
Hard to say what to recommend it is messy since nothing is standard.
Maybe buy another wifi device/bridge and connect that to the lan in build b and the that device will pair with the wifi in building c. Might be worth the $50-$75 rather than deal with the hassle of mulitple repeaters.
Reactions: lantis3
How? Through ethernet cable? Sim router are supposed to connect to T-Mobile tower wirelessly.
Did you setup correctly?
Intro to Ubiquiti PtP and PtMP Radios
After re-reading your posting, there are a lot of conflicts.
You said connect a laptop to the LAN port of the AC1200 and have a good internet connection earlier but later you said it does not work when you connect it to the LAN port on the AC1200 router. so which is true?
And which T-Mobile cellular router do you have? If you have a data plan on the sim router, of course you will have internet whether you connect to it with cable or wirelessly.
Have a diagram (pencil/pen is OK ) and post it to imgur.com and label wired connection with solid line, wireless connection with dash line. Also mark which works and which doesn't.
I'm not an actual Ubiquiti user. But my guess is
buy another nanostation, you also need to add AP in building B and C
Your TP-Link A54 can act as AP in building B
Code:
   Building A                     Building B                Building C
Fiber wifi router  --------   Nano A ====== Nano B  ------    Nano C
                           Bridge mode     AP mode          Bridge mode
where single dash line - wifi   double dash line - ethernet
Take your question to Ubiquiti forum probably will get you a better answer.
Thanks for the replies and thoughtful answers. I may have been too brief in my original question. I am in a very rural area so security is not a big issue. The fiber internet is in my cabin (Building A). Next to my cabin is a guest cabin (Building B). My pole shed (Building C) is about 100 yards away. I was originally using the Tmobile cellular internet in my guest cabin and using the Ubiquiti bridge to get internet to my pole shed. Everything worked fine in this scenario. My goal is to get rid of the Tmobile router and save $50 a month. I added the A54 router to my guest cabin and wirelessly connected to my main cabin fiber router. This works fine . The problem is when I connect the Ubiquiti bridge via cable to the A54 router in the guest cabin. I now do not get internet in the pole shed. Based on the answers I received, it sounds like there may be a workaround but essentially wireless connections are not intended to support this type of connection. I am not opposed to purchasing new hardware, I just want to make sure that conceptually it will work in this configuration.
Regarding:
"The problem is when I connect the Ubiquiti bridge via cable to the A54 router in the guest cabin. I now do not get internet in the pole shed."
What IP addresses are being used? DHCP or Static? Subnet masking?
What device ports are being used for the Ethernet wired connection beween Nano A and Nano B?
What type Ethernet cable?
I am missing something: "does not have nano A" or
is it meant [my words] "does not need nano A" ?
I always wonder about the physical ports being used: WAN or LAN etc.?
And, of course, the IP addresses being used....
My suggestion is for the OP to expand the line diagram accordingly - details matter.
The 100 yards distance to the pole shed is likely pushing the limits: expecially if not open space.
OP does not have nano A , and Nanostation only has one LAN port.
OP should have set a static IP for nano B and nano C and that should be the correct way.
Thanks - my misread. Apologies.
So this line diagram - provided that I am following correctly:
Building A Next door Building B (Add Nano A) 100 Yards Building C
Fiber wifi router -------- Nano A[LAN] ======[LAN] Nano B (Static IP) ------ Nano C (Static IP)
Make/model? Bridge mode AP mode Bridge mode
where single dash line ---- wifi double dash line === ethernet
Not sure about the router in Building A or the presence of the TP-Link AC1200 router in Building B.
Please feel free to edit, correct, and update as necessary.
