problem to on lap top after shutting down due to low battery
same thing happens for me n one thing battery is non removable
please suggezt m charging and both the power light and charging battery light is on but the laptop is not on ...help
If both lights are on, it is actually possible it is on, just the display isn't. Try this...
1. Turn the laptop off (not sleep or hibernate but off).
2. Connect an external monitor to the laptop.
3. Turn on the external monitor.
4. Turn on the laptop.
NOTE: You may have to press an "external monitor" button. Could be the f4 button or a button with two monitors on it, for the external monitor to work.
If you can see fine on the external monitor, then your attached display, or the ribbon cable that connects it, are your problem.
If you can't see on the external monitor at all, or the problem occurs on the external monitor as well, then it is probably the graphics card/GPU that is the problem, which may require the motherboard be...
If you can't see on the external monitor at all, or the problem occurs on the external monitor as well, then it is probably the graphics card/GPU that is the problem, which may require the motherboard be replaced.
CTRL + SHIFT + WIN + B forces a refresh of the display driver which can also fix this issue.
Latest posts
