Good Afternoon. The forums in this website have been very helpful to me in the past, so I was wondering whether or not I could find some assistance as to establishing a connection with my MoCA adapter.
My Situation:
My overall objective is to improve the reliability of my connection to the internet. Initially, I’ve been relying on a DW1525 (802.11n) WLAN PCIe Card (in other words, the default wireless card that came with the PC) for a wireless connection. There are times, however, when the connection just dies, and I am forced to go into Control Panel --> Network and Internet --> Network and Sharing Center --> Change Adapter Settings and use “Diagnose this connection” in order to refresh it. As a side note, it isn’t uncommon for this method to fail, at which point I just restart the computer. And then sometimes, the reboot doesn’t even do it either! Add to this the fact that I have to compete with my siblings who use a smartphone and iPhone 5, which almost certainly contribute to some pretty bad lag spikes at times. The point is, I would like the peace of mind that comes with a wired connection so that I do not have to interrupt my games (or other activities for that matter).
So on that note, I did a little research and decided to purchase the Coax-over-Ethernet MoCA adapter (paired) to take advantage of the coax port coming out of the wall in the office room where the computer is located. So I’ve set the two of them up (i.e. one connected to my gateway and one connected to my computer), and something interesting has happened. The connection is clearly there (that is, I’m 99.999% positive I’ve hooked it up correctly, lol), but it has been labeled an “Unidentified Network” and not actually giving me access to the internet. I also notice the green “Coax” light is not on, but the “Power” and “Ethernet” lights are. In addition, when I flip the switch in the back of the hardware to “Config”, it is the “Coax” and “Ethernet” lights that are on and the “Power” light that is off. I know that there is at least something because I see packets have been sent though not received when I right-click and check “Status”, and there is no little red ‘X’ denoting a break in the connection. I feel like the solution I am looking for is just outside the reach of my fingertips...
My Hardware:
Gateway: 2Wire 3800HGV-B
MoCA Adapters: ECB2500C (x2)
- have black coax cable between “Cable Line” port on gateway and “Coax In” port in MoCA adapter
- have black coax cable between “Coax Out” port on adapter and port coming from wall (router is located downstairs, diametrically opposed from upstairs office room)
- have Ethernet cable between adapter and router
- have white coax cable between port in wall in office room and “Coax In” port on adapter near the computer
- have Ethernet cable from adapter in office room to computer
- the “Cable Line” port in the router affects the cable signal to the television in the entertainment room, so I know I at least have something set up correctly (otherwise, the TV would not have a signal)
Wireless Card: DW1525 (802.11n) WLAN PCIe Card
PC: Dell Inspiron 580
- i5-650, 3.20GHz
- 8GB RAM
My Software:
OS: Windows 7 Home Premium
- 64-bit
Subscription: AT&T UVerse
One Last Question: Is there any significant difference between white coax cables and black ones? Whenever I go to Home Depot, I notice that the white cable cost more than the black ones.
My Situation:
My Hardware:
- i5-650, 3.20GHz
- 8GB RAM
My Software:
- 64-bit
