Problem when holding down a button.Please Help
Abnormally Skilled
20
Hello Guys I just bought CoolerMaster Masterkey Lite L and here is the issue:When I hold down a button It doesn't do the thing once.(for example when I play cs and want to hold down w to walk, it keeps on doing little steps very fast)It works like when you hold down a letter for some reason.How can I disable it?Is my keyboard faulty?
Thanks
Not sure that I am following the issue: holding down a key normally makes it repeat.....
Check the keyboard settings via "Ease of Access". "Filter Keys" may be what you need.
Or otherwise check any keyboard configuration software that you installed via the keyboard or some other source (game).
