M Mike_183 Commendable Mar 25, 2016 3 0 1,510 Mar 25, 2016 #1 so when i plug my 4pin cable int to the mobo the pc doesn't start but when i remove the cable my pc starts and everything works flawlessly,all the fans are spinning and everything seems to work just fine so do i realy need that 4pin 12volt cable?
CountMike Titan Oct 31, 2015 35,991 3,986 147,990 Mar 25, 2016 #2 Usig IGP ? If yes, you wouldn't need it than. Upvote 0 Downvote
M Mike_183 Commendable Mar 25, 2016 3 0 1,510 Mar 25, 2016 #3 CountMike : Usig IGP ? If yes, you wouldn't need it than. This may sound stupid but where do i see if my MoBo has an IGP checked the manual and it dosent say anything Upvote 0 Downvote
CountMike Titan Oct 31, 2015 35,991 3,986 147,990 Mar 25, 2016 #4 IGP is built in graphics as opposed to discrete graphic card. Upvote 0 Downvote
M Mike_183 Commendable Mar 25, 2016 3 0 1,510 Mar 25, 2016 #5 CountMike : IGP is built in graphics as opposed to discrete graphic card. ok Thanks for the help! 😀 Upvote 0 Downvote
