ah
I would really try to update your BIOS, mobo chipset drivers, and video card drivers first.
make sure in your BIOS, you have the option enabled that lets USB devices wake the pc
a processes called NBService.exe (Part of Nero) can interfere w/ waking up from sleep. so if you have that disable it
if that doesn't work, make sure everything in the power options in control panel is @ default
