So I have a dual monitor set up with a 1080p and a 4k tv. The 4k tv won't fit to the entire screen, when it is set at 1920x1080 resolution. Also I learned from taking a print screen that there is a third screen I didn't know about.
How do I get the resolution of the 4k tv to fit the entire screen?
Can I set it to a higher resolution that would still fit the entire screen?
How do I get rid of the third screen?
Pics of the monitor cables connecting to the tower and a pic of the 4k tv resolution not fitting.
http://imgur.com/a/sccAX
The print screen showing the third monitor I didn't know about.
http://imgur.com/nHvQOpF
List of my pc parts if needed.
http://pcpartpicker.com/p/ykskYJ
Update: I was able to remove my that third desktop that I didn't know why it appeared. I just had to go into AMD Catalyst Control Center and go under common display tasks and disable it.
