I have an AMD K6-2 at 400 Mhz with 128MB SDRAM. The motherboard is a LuckyTech P5MVP3 with the VIA Apollo MVP3 chipset, and it has an AGP 2X slot.
I had a S3 Trio3D/2X AGP 2X card with a 3dfx Voodoo2 as child card, and until now I hadn't any problem. But recently, I replaced them with a 3dfx Voodoo3 3000 AGP 2X card. I plugged a fan above the video card to avoid reheating, but the system reboots or hangs up when is turned on about 10 minutes (during this time, the system works properly). This time may be shorter if the system is overloaded (i.e., when executing DirectX games or when playing MP3 files under Windows ME). The Voodoo3 card was tested in a different system, and it worked perfectly.
I wonder if the Voodoo3 3000 video card is too much powerful for my motherboard. May be a compatibility issue? Currently, I'm using the old S3 card.
Please, explain me if my Voodoo3 video card is NOT supported by my motherboard, and if the answer is yes, what video card can I purchase that will be supported by my system (with a similar performance). I tried a nVIDIA GeForce256, and the problems were harder: the system hung up during the P.O.S.T.
Waiting for your reply, thanks very much for your help.
