Problem with AMD PRO 5100 WX Displayport
giovanni.nembrini
7
Hi, i've built this Pc:
Motherboard: msi tomahawk x299
graphic: Amd Pro 5100 wx
Processor: INTEL i7 7800x
power supply: Corsair 850
SSD: Samsung m2 960 evo
The graphic card I think is ok cause the fan is active. But when i plug in the displayport passive adapter to vgi (that was inside the graphic card's package) signals is missing. I can't understand why, the adapter is passive but i use a M/M DVI D Single link cable to link graphic card and monitor (a DEL 1911b).
Any suggest is accepted.
Hmm are you SURE the cable is actually a DVI-D cable? Otherwise i'm not seeing any reason it shouldn't work. Is the monitor on the DVI source, and not on the VGA source? (have to change the input it looking at for a signal)
No, Ram configuration is ok. I've tried to change or use one slot only but nothing change.
Further when pc starting after one secondo restart itself and stuck with dram light on.
One pic
https://1drv.ms/i/s!AonOjSsHcV7NhJMBREeuP3qLNQtlgQ
Nothing change without graphic card.
