Problem with ASRock Z97 Pro4 stopped BIOS clock
C00KI3S
I feel like I've tried everything at this point: reinstalled windows and all drivers twice, updated BIOS, did all types of BIOS resets (turning off switching CLRMOS back - this makes it work when it first turns on but when I restart it stops again), disabled/enabled the clock utility (forgot the name), switching my network connect (it wasn't connecting through wifi :S) and finally changing the CR2032 battery.
After I switched the battery the clock was jumping all over the place, then when I synced it in windows, it stopped again. 🙁 Anytime it works, and then I sync it, it stops.
ASRock Z97 Pro4
i74790k
EVGA Modular 600W
8gb ram
Geforce 750 ti boost
Any advice would be appreciated, this is a new build, 2 weeks old. I did purchase the replacement plan with the motherboard (thank god), anything else worth a try before I bring it back? 🙁
Edit: I haven't oc'ed. And I'm using Windows 8.1 64-bit.
