We tried installing this CPU on the Z87-C. It does not work the CPU light flashes.
What we did:
1) Install the CPU turn it on with a red flashing CPU_LED on the motherboard
2) We figured we needed to update the bios for Devil's Canyon CPU's...(We used EZ Flash 2 utilty)
3) We updated the BIOS to the latest using my own i5 4670K which DOES work on this Mobo(So it's not a motherboard issue!).
4) Still not working after BIOS update
now here's the really odd part:
5) We have another motherboard with a faulty network controller(A Gigabyte Z97 Gaming 3, hence why we tried using this mobo) where the CPU STILL WORKS ON! So it's not the CPU EITHER!.
RAM works we tested it we even tried different RAM, PSU works everything works on this Mobo.
We also confirmed the CPU still working...
Even the Support site says that this CPU is supported with latest BIOS which we properly installed(I'm 100% sure)
With all these steps we've also tried resetting CMOS multiple times
Now what am i supposed to do?! My mind is blown with this because every part works on its own, but this particular CPU does for some reason not working with this particular motherboard even though the support site says that it should!
Specs:
ASUS Z87-C(Replacement for the Gigabyte Z97 Gaming 3)
i5 4690K
8GB Crucial Tactical 8GB DDR3 1600Mhz 1.35V(We also tried some older G.skill ripjaws 1.5V DDR3 1600Mhz)
Samsung 850 EVO 120GB
1TB HDD
What we did:
Specs:
i5 4690K
1TB HDD
