Problem with 'Backup'
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.win2000.file_system (More info?)
I installed and am trying to use NTbackup.exe for the first time on my Windows XP PC. I have no problem burning a CD when using Sonics "Record Now" but its slow (or appears to be, took 25 mins to burn a 700mb disc). I would rather use the Windows backup. The wizard opens and I can choose files, folders etc. but when it comes down to backup where and I choose E: as the location (my DVD/RW ) it says "The backup file name could not be used" E:\cj backup.bkf "Please insure it is a valid path and that you have sufficient access."
As far as I'm concerned the path is correct and the name is legal. Can someone tell me why it won't go further?????
Thanks
Because NTBackup doesnt support backup to cdr/cdrw
"Catt Jelly" <anonymous@discussions.microsoft.com> wrote in message
news:F32F0E8A-3543-4D43-B710-3FCC582E1002@microsoft.com...
> Thanks
Really? Do you know of one that does??? I've read in the Knowledge Base that the backup program is available on The Windows XP CD Rom and can be installed from it. What if the XP came with the PC is there a way to do that?
Thanks for the reply
Catt
As far as I'm aware none of the MS o/s backup utilities write directly to
cdr/w though you can backup to tape.
There are a number of third party backup apps the will backup to cdr/w eg
Handybackup or Backup plus
news:E3A7D184-B7D9-4CBE-A266-8E493E1B3B2A@microsoft.com...
that?
> Catt
