I'm tyring to put together a mini-pc to use as an entertainment center. The hardware put together for this is:
antec aria case
chaintech 7nif2 microatx mobo
mobile athlon xp 2400
1 stick of ddr400 512meg ram
HD and dvd burner (i'll be adding tv tuner cards later if/when i get the thing working).
i spent several hours just trying to get windows installed and couldnt do it. The machine gives me BSOD with various error messages at various points during the install process. the most common error is irql_not_less_or equal or driver_irql_not_less_or_equal
i get this even before windows actually starts installing, when its just copying files from the cd. Its also come back and said the HD was bad and it couldnt format it (tried it with 2 different drives). And it also fails sometimes with no specific error, just saying there was a hardware failure. I've tried disabling everything on the board that i dont need to just get xp installed, but it doesnt help.
I did get xp to install just once, the very first time i tried. but it BSOD 5 seconds after i logged in.
Also, not sure if this is related, but when i boot up, the bios screen says the cpu is a mobile athlon 800mhz. I believe the mobile 2400 should should up as 1.6ghz or 1.8ghz.
There is nothing i can see in the bios (or jumpers) to set the voltage or multiplier speed. Just the FSB speed which i set to 133.
I dont think its overheating... the cpu temp seems to stay at around 110f.
Does anyone have any suggestions as to what going wrong here?
thanks in advance for any help anyone can offer.
antec aria case
