Problem with Corsair iCUE
saintzrowicon
9
I just installed a new CPU cooler (Corsair H60 (2018 version)) and am having some problems with the software. As noted on the installation guide on the cooler, i plugged the 3-pin connector from the pump to the CPU-FAN header on my motherboard, however in the software it is telling me my "Fan #1" is running EXTREMELY fast (3900-3999 RPM). In the software, I am also not able to see all of the temps on my mobo, as Temp #3 and 4 are just not showing up.
First, the H60 isn't controllable via iCue.
And many motherboards have phantom temps on the motherboard in iCue. This is due to the sensors actually being reported as being there, even if they aren't. And the CPU Fan will, IIRC, be showing the pump speed.
I assumed that's what was showing up instead of the fan speed, but I didn't know pumps ran that fast. Thanks for the help!
