Problem with Corsair K70 RGB
Slinix
15
Today I spilled diet coke all over my K70 and dried it off and cleaned it, I set it to dry for the day and when I plug it in no leds turn on, totally unresponsive, but a page in file explorer comes up with the title of CRP DISABLD (E:) and the file firmware.bin in it. This happens any time I plug it in. Not sure what this means, any help would be appreciated.
If the keyboard doesn't turn on after being plugged in, then it's fairly likely that your board is fried. However, CRP Disabled is usually attributed to Corsair devices being sent into bootloader mode, which with mice and keyboards means it's a removeable USB device.
If your coke got underneath the spacebar, you're boned. If you take off all the keycaps, right under the spacebar is where a part of the actual silicon board is revealed (i have an older version of a K65 that has this - perhaps it isn't the same for newer versions of K70s). If coke got on that, it's fried.
Talk to Corsair support, they know the steps to get it off bootloader mode if it's not actually fried.
