Problem with Corsair Link
Prasadcge
15
i had Corsair HX850i PSU and H100i GTX Liquid Cooler..I had two problem with these two products while trying to use Corsair Link...
1. HX850i PSU was showing in the Corsair Link Software but the problem is it shows Fan: 0 RPM..
if i go to Device Tab in Link software der it shows :
Corsair HX850i PSU Firmware Version : Not applicable?
2. H100i GTX is not shown in the Link Software and in Device Tab?
Why i am facing this problem?
By the way i'm using windows 8.1 and Corsair Link 4.2.0.162 the latest Version right now...
What the Hell is happening with the Corsair products...
if u have a solution Plz help me i will be very thankful to you.
G
Ill just be blunt about this. Remove Corsair Link and your problem is solved. Take the Corsair Link dongle and put it in the garbage. Download HW Monitor and Riva Tuner and set them up to display the same stats in your taskbar.
I had no problems with corsair link, but some people have mentioned they do. make sure you plug the proper cable into the cpu fan header not just a standard fan header. Plug the other 2 into a female fan header on your case or on a standard fan header on the motherboard, which will give you must more control of the fans since they arent PWM
