Problem with Corsair Vengeance
omarjoel
I have this problem: the memories corsair vengeance at 1866 MHz, run at 1333 MHz, when I change it to 1866 windows shows me a blue screen and will not start.
U can try to boot using 1333Mhz setting first. Then check the RAM timing for 1866Mhz using the CPUID, and manually input the settings into your BIOS. I did the same thing as well and my 1600Mhz Corsair RAM boot with no problem. Previously, there is no display at all if I leave the setting as AUTO in the BIOS.
