• Find an incredible deal for Black Friday or Cyber Monday? Share those epic bargains with the community by posting them in this forum thread!
Question Problem with CPU OC
Oct 28, 2019
Hello,
I recently built a new PC and tried to run the Msi Kobustor but as soon as i start the stress test, it freezes and my pc crashes. I have tried different stress tests.
My CPUs ghz was also jumping around like crazy (from 1 ghz to 4 ghz) but now i saw some forums and changed the power options for CPU in the power plan settings.
But Kombustor is still crashing even if i now got my CPUs ghz better, now it is about 3,6 - 4,1 ghz. 3,6 is btw my CPUs base clock, which makes sense because i put the minimum power limit for the CPU to 100%.
Yeah, i use the CPU-Z. (the program where you see your hardware stats)
Leave XMP on but remove all other changes. I would reset the BIOS to default and just switch on XMP.
Sorry for replying so late, but i think that fixed the issue when i decreased the overclock in Msi Afterburner, the overclock wasn't even that high.
Thanks a lot!
