Darkbreeze :
What are your hardware specs. Model numbers and components will help to help you.
hi bro, i really need help, i have strange issue..
i also asked in many forums but i have not got replied,
its been year with my current monitor "Philips 203v5... " using Dvi to VGA connector,
month ago i had gtx 760 on windows 8.1, everythings were fine, infact monitors also regonised well as in graphics property "philips monitor"
but now, when i got New Asus Gtx 970 strix, everythings working fine in performace, but facing this strange issue,
Whenever my PC monitor gets sleep like in "10 minutes idle or CPU sleep or in Shutdown or just UPS power turn on(without running PC"
it continue says " No Signal-Check Your Cables" instead of Black display with monitor power button light blinking
even if i just turn UPS on before turning CPU power on, the same msg i get.
When my CPU get sleep or idle sleep, it gives same msg But when i wake mouse it behaves normal,
this problem is not creating any issue while using PC,
it behaves normal after sleep (mouse wake)
also i noticed that my Monitor is known as "Generic Non-Pnp Monitor" in resolution property. (but in gtx 760 i got monitor name properly)i tried to update monitor drivers, but it says "already up to date" so im not able to install it.
i also tried to install windows but still no solution,
