I started getting error the other day and it is generally happening while I play a couple different MMOs. It essentially causes my game to crash. This is while playing Archage and the new Battlefront, but not WoW. After it happens I fire up the EVGA OC Scanner and run it and check the FPS. Generally after the error occurs my FPS drops from the normal 170 or so that the scanner shows down to around 35-50 FPS.
My "fix" is to just reinstall the video drivers (was using the newest 359 drivers from Nvidia) and that seemed to resolve the problem for a time and then it happens again. I have just now gone back down to drivers 358.xx.
My video card is a EVGA GTX 750ti FTW. My power supply is a couple months old and is a Corsair CX600M 600 watt power supply. My motherboard is also only a couple months old as I purchased it the same time I did the power supply. The motherboard is the ASRock Z77 Extreme4 LGA 1155.
Any ideas what it can be?
It just seems strange that it could be hardware if reinstalling the video drivers fixes it for a time.
I have also noticed that as long as I don't overclock the card, I don't have an issue. However, the OC that I use has been stable for months. Using Precision X 16 I bump the GPU Clock up by 115 and the memory clock by 15. I also raise the mVs by 12.
