Problem with Fan on DELL latitude - plz help!
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I have an annoying problem with my dual Fan C810 laptop.
After some hours usage (usually) the fans when turned on
(automatically) make a grating noise - very loud and can be heard in
the next room.
I suspect it has something to do with heat expanding the plastic? As
after cooling the fans seem to revert to normal behavior.
The behavior affects both fans - sometimes simultaneously sometimes in
isolation (I used a fan control program to test this)
I have managed to make the problem acceptable by running the CPU
permanently at 733MHZ (speedstepped from 1.13GHZ) - no great problem
for me as I only surf the web and use Office programs - but the
problem doesn't go away as the fans invariably need to be used and
switch on automatically and voila.... after a while the grating noise
reappears.
The Fan control program I use "Fan Control 2.2.0" by Christian Diefer
allows me to turn off the fans permanently. Now.. at 1.13GHZ I guess
this would make for a fried motherboard - but speedstepped permanently
to 733MHZ (via the authors Speedswitch XP) could I get away with this?
The temperature at the lower speed rarely reaches 60C and averages
around 52-55C... cooling required?
Thanks for any help
Chris
I can be e-mailed at: athena (at) rol (dot) ru
replace the fan and run the system as it was designed. there are several of
those fans listed on ebay starting at $10 (perhaps the same price as dell?)
and the service manual is available for free here
http://docs.us.dell.com/docs/systems/latc810/sm_en/index.htm
"rfc" <rfc2000@usa.net> wrote in message
news:rlhc90lq8su6kg6njj20i36dambie6o2g0@4ax.com...
> the next room.
> reappears.
> Thanks for any help
> Chris
On Mon, 03 May 2004 14:05:23 GMT, "Christopher Muto"
Thanks for the advice - however having an earlier C800 the same
problem occurred leading me to believe it is integral in the design
and a new fan would perform similarly under heat stress
What I need to know is as before, does the CPU need cooling below 60C?
thanks
>> the next room.
>> reappears.
>> Thanks for any help
>> Chris
i like to solve the cause of a problem and not a symptom... but this should
help you decide whatever it is that you want to do...
http://www.intel.com/support/processors/mobile/pentiumiii/sb/cs-007510.htm
news:j8lc905a6d41k0ahed13i8vckt18ro56gh@4ax.com...
of
dell?)
> thanks
> >> the next room.
> >> reappears.
> >> Thanks for any help
> >> Chris
