Problem with fans AORUS GTX 1080TI EXTREME EDITION
rvd150
111
When I stop the game, sometimes the right fan continues to spin and never stop. And the other two fans stop.
To stop it I should restart pc
I can't find specifically what the rightmost fan is cooling - but it's possible it's taking longer for that area of the card to cool down.
How long have you actually left this? The fan may never be designed to full 'stop' on the basic fan profile.
Are you monitoring temps?
What happens if you set a custom profile and raise the temp at which the fans spin up? Does the fan stop then?
Not encouraging you to raise the temp at which fans spin up permanently, but for troubleshooting purposes - it'll give you an idea.
I didn't try make custom profile but idont know why sometime this fan not stop does is problem in my card of that's normal ??? I want quickly answer if my card have problem I will returne it
Please do not 'bump' threads: as per http://www.tomshardware.com/forum/19-73-forum-rules-read-first
We cannot state definitively whether this is "normal" or not for the card. It doesn't sound right necessarily, but it may just be the area of the card/PCB the rightmost fan is cooling takes longer to get back to 'lower' temps (low enough, as per the basic fan profile) to slow down/stop.
I suggested a custom fan profile, and questioned whether you're monitoring temps.
Please provide this info before we can do anything further.
I don't know how I can make custom profile on AORUS engine
I found problem the fan stop light work when fans is stop and the light off when fans work
Now my problem the fans stop and the light not work what that
Is the Aorus engine set to run at startup? I'd start by disabling that. From a quick google search, others have had the reverse of what you're experiencing (no fans spinning, when they should) that has been linked to the software.
Again; please do not bump threads.
