[SOLVED] Problem with filmed files. Filmed with Panasonic VDR-D150 camera
Nov 22, 2020
Hi, I have filmed several scenes with the Panasonic VDR-D150 camera. The disc has been finalized. I can see all the scenes on the camera, but when I connect the camera to a PC or insert a disc into a PC, it shows the disc to be empty. Where is the problem and how can I fix it? Or where? Thanks.
The warning on page 81 from below, a few pages later states that a flash drive
may become unreadable as well. My guess they are formatting so that a computer can't
read.
Try different types of formatting and see if one works!
https://www.manualslib.com/manual/117431/Panasonic-Vdr-D150gn.html?page=81#manual
"Use this unit to format discs. This unit may not
recognize some discs that have been formatted
using a computer or a device other than this unit"
read.
read.
Thank you. But if I will try - is it possible I will lose my already filmed files? And it all happened the only a couple of disks (that problem). For another's everything is fine.
