Problem with first Half-Life
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.games.half-life (More info?)
I have a problem.
When I try to open half-life, It will not take the CD, Therefore I can
only get to the main menu.
Is there a Patch to run it with out the CD?
My dad will not let me use Steam. Don't send me any links to that or
the tech support place.
I got this error message after waiting 10 minutes for it to download,
then running it:
Could not initialize installation. file size expected=86011604, size
returned=57671680.
and what does HTH mean?
> Are you on broadband?
I hope that is how you quote...
.... yes. Yes I am
one of the downloads worked
"Robtcee13" <Robtcee13@yahoo.com> wrote
> I have a problem.
The later patches *before* steam was implemented used a no-cd crack...
http://www.fileplanet.com/57317/50000/fileinfo/Half-Life-1.1.1.0-Client-(Full-Client)
You will need to register to download it.
HTH young man.
David
davidfirewater(a)hotmail.com
> then running it:
> returned=57671680.
ah heck, bad file or bad download
Here's some more links
http://downloads.gameplanet.co.nz/cat.dyn/Half-Life/Official/
http://www.gibgames.com/files.php
http://www.ausgamers.com/files/details/html/2457
http://editingarchive.com/view.php?ID=193
Try searching on Google for more
HTH = Hope This Helps 🙂
- Peter
Close enough :)
> ... yes. Yes I am
Just wondering if it was fileplanet (again) or a bad connection
Hurrayh - and good luck
and - please - no cheating until you have finalized the game 🙂
- Peter
